1 - 20 of 233 Posts
ive learn a lot from this site and I feel like you guys might like my build
feel free to comment or suggest anything
im at the point the engine is mocked up and just waiting for transmission adapter
ill probably need help with wiring the engine ....
it should be pretty easy tho
enough BS and here's some pics.
ive been posting some pics of the project on FB
just now got time to upload pics to photobucket
this build been going on for past 4-5 months
using Nissan TD42t turbodiesel engine out of dump truck that my boss give it to me
only problem was transmission its 2wd and manual
im right leg above amputee and cant comfortably drive stick (I could but would need hand throttle )
so first on the list was get auto tranny that will work with this engine
problem is this engine didn't came with auto tranny and 4wd so after long search on internet I found out that this TD42 engine is used in Nissan patrol and is very popular in AU but rare with auto tranny
I had option to import tranny from there or find adapter to fit tranny that's easily found in US
I found guy who does conversions from Nissan Z to GM tranny and called him and he told me that hes working on same engine for AU
guy who building the fastest desert truck ... sweet
I scored rebuild 4L80e transmission with transfer case out of diesel truck with wiring harness and computer
it was out of 91 truck that had standalone computer so it "should"be easy to wire it up
I got 80's cj7 that I bought for short money cause the guy was swapping body and never finished
stripping was very easy as th ebody was just sitting on the frame and everything disconnected
striping the jeep
4.2 removal
tub on the way home
paint stripped and power washed
bought donor jeep with my buddy aaron for 400$ he also building pick up
moved from my house to my buddy shop
he let me use his shop after work hours
mock up with bed and wheels (35")
Discussion Starter #7
this is past weekend frame work
started Friday after work and rolling chasis was out of shop sunday 4PM
that's with removing ford explorer axle
made wooden template as I needed to go up and out
Discussion Starter #9
ford explorer 8.8 swap
need to do SOA but not enough time to cut off the spring perches so I flipped axle and mounted spring on top
good enough for mock up after I flipped it it was perfect height
out of shop on its own
body and tub sitting on the frame
still need to notch the cab to slide it 6"closer toward the tub
it is hitting frame
1 - 20 of 233 Posts
