Now everything decides to break
Hey all. problem time. as some may have read, i had a fuel problem the other week that when i was on any slight incline i would run out of fuel. started chasing this down and stumbled upon the fuel filter, it would block when the front of the car was lifted. bizzar, yes, but thought cool, i'll get a new one. also thought seeing my trip is coming up i would take out the radiator and give the cooling system a flush out, small service and also tidy up some of my electrics.
All well and good. fit up day come today, only one small coolant leak, my fault. dried that up, got all the fuel system fit back up, checked for leaks and she was all clean.
yay happy me.
Now the test drive.
I now have what i guess you could call it a flat spot where it splutters a bit up until about 3000rpm. in and out of the shed playing around for about an hour and still no result so thought i will leave this for today, cant for the life of me figure out what is causing this.
Then i look under the inlet manifold and what do i see, an oil leak, slowly coming out down the block. wasn't there when i was checking that area earlier in the day and it just keeps creeping its way down the block while i get more and more Pi$$3d off.
Oh yea thats right and its getting time to have a look at the clutch and thrust baring, its developing a crunch as i let the clutch out in second and third gear.
So the new things to fix, this oil leak and try and suss out this fuel problem and the clutch. what a joke.
yay happy me.
Now the test drive.
