Ok, im less than unimpressed! I made the major investment of upgrading my TD42 GUII with a PWR fully alloy radiator in the hope that it would sort out any cooling issue's i may have.
As it turns out, 2 years down the track, the PWR has developed leaks where the header tanks meet the core's! My friendly local radiator tech and PWR agent has informed me that the Nulon coolant that i have used has caused corrosion on these joint's. A 2 part epoxy was applied and with a wave and good luck quote, i was away again! I have no idea how long the epoxy will hold for and am reluctant to travel any great distance in case it let's go. My question's are....has any one else experienced this with this particular brand of radiator and could it be a welding/manufacturing fault when built? Also, has anyone experienced any negative corrosion type result's from use of this particular brand of coolants?
I simply don't have $1200.00 too splash around again on a new rad that i assumed was a top quality product and the chances of either manufacturers of these product's helping me out would be very limited i assume! Not happy Jan!
