1 - 7 of 7 Posts
just a good guy.
2009 gu ute
use that in my gq diff and runs smooth as silk. run nulon in all diffs. transfer case, gearbox and engine only because get for free :p:coffeeti:
I used the straight LSD 140 oil.. I dont believe the Nissan diff likes a "multi grade" oil... Just what I was told.. not gospel..
Go Hard or Go Home
Depends on the climate/ambient temp.
Cooler climates, run the 85W-140.
Hot climates, run the straight 140 weight oil.
Either will be fine once upto operating temperature of around 120 to ~180degC depending on what the vehicle is used for, eg towing or not towing.
thanks for the feedback. i do tow but not much maybe a car trailer 3 times a year if that it is manliy used for 4wding and everyday use. i think i will put it in and see how it goes and change if i have to. thanks
well i changed my diff oil 2day what a pain in the arse that was the oil wasnt to dirty it had a few fine bits of metal on the magnet. but it only took 2.1 liters max i thought it was ment to 2.4 can anyone confirm this. chears
1 - 7 of 7 Posts
