Okay so I have a tb42 swb manual. And have already cooked one motor don't need to do that again. So my question is if a oil cooler is fitted will the service intervals be longer? And will it make a reasonable difference to the life of the engine?
When fitting water temp gauges where is the beat place to tap into for the sensor? And Same with oil temp and pressure.. Now ATM the engine does run cool. Just I've had slot of reliability issues with this car and want to keep the car running reliable. I would like to be changing the oil every 10k kms.. Instead of 5k. As uni takes up most of my money =(
Thanks for any help
Thanks for any help
