I am turboing a TD42 (they never sold turbo'd ones here in UK) Im taking the oil supply from the gallery in the LH engine mount bracket, but i need to plumb in the return. I presume there is a reason why people don't connect this to the brake pump return, so I will fit a barb on the sump.
I'm guessing its not possible to do this without taking the sump off. Engine is out at the moment. Does it matter if it goes on the side or on that horizontal bit of sump? What size should it be, about 15mm?
Thanks
Thanks
