Hi all, just wondering if anyone has had this or similar leak coming from the compressor housing on their turbo. not to knowledgable about this stuff. have been told its not an urgent fix but wanting to double check. TIA
Automotive tire Motor vehicle Gas Automotive exterior Automotive fuel system
Hi all, just wondering if anyone has had this or similar leak coming from the compressor housing on their turbo. not to knowledgable about this stuff. have been told its not an urgent fix but wanting to double check. TIA View attachment 535051
Take off the alloy pipe in the upper right of the pic and check for the quantity of oil in it.When the shaft seals fail it looks like this,just a bit messy initially but it can steadily fill an intercooler and worst case the engine can start feeding on the oil and "run away ".
thank you, is there meant to be oil going through that pipe? and if so how much should there be
Any oil in that pipe is from leaking turbo seal,it should be clean,maybe a minute amount ,but not leaking out like you have,it is the boost air pipe to the engine,via an intercooler if you have one.
ill look into it. thanks mate!
Is there anything inside that pipe in centre of pic (that connects to the orange hose) that could fall out when undoing it ?
