There should be a restrictor in the turbo feed banjo,if there isn't the full flow will fill the bearing cartridge before enough builds pressure to the engine,not good,don't rev it on start-upTd42 aftermarket turbo kit fitted on start up the oil pressure light stays on for about 5 seconds max is this an issue?
