1 - 5 of 5 Posts
Behind Enemy Lines - Toymota Driver
Doing a conversion and have fitted a tb42e and its harness. Can't get the dash lights to work so I removed a globe from behind the cluster to check for earth and find I have 12v on both sides of where the light fits. I have checked all fuses and swapped relays, also have no blinkers and have checked the flasher can. Any ideas?
behind where the the radio is there is 2 plugs that look the same one if for the a/c button the other is for somthing else not sure ?? anyway if you plug the wrong one in it sends power through all the light system when the a/c button is presed. i think that makes ur lights stay on not off but its worth a look
did you find your problem?
Yes, The hazard lights were plugged in wrong and in removing the cluster my young bloke had earthed it against the body while the parkers were on ..melting a track on the board, all fixed. Thanks.
1 - 5 of 5 Posts
