1 - 11 of 11 Posts
I have my trailer hooked up to the Patrol with a 50 Amp Anderson plug which charges the trailer's deep cycle battery. Have done about 20,000 km with this set up - all OK.
Last week, on the way to Googs Track, I noticed the battery was not charging.
Called into a tractor/machinery dealer at Wudinna, looking for an auto electrician (they did not have one). I left the car (4.8 L auto) idling for about 15 - 20 mins while we fiddled around with the trailer Anderson plug, removed & reconnected it many times, cleaned the terminals, etc & generally investigated. Could not get the battery box display to read that it was getting a charge. Gave up.
Then I went to drive away - DISASTER ! Immediately felt loss of power & revs. Could not get over 2000 rpm and it took forever to get to that point. The engine management light became illuminated. Headed to Ceduna in the attempt to solve the issue with a Nissan dealer via their diagnositics unit.
The manual says OK to drive but may notice power loss & increased fuel useage. Sure did! I estimate we were getting 40 L / 100 km at approx 75 kph - max 80 kph. Camped between Wudinna & Ceduna, again removing plug & trying to solve the engine m'ment issue as well as the fridge charge issue.
While waiting next morning in Ceduna for my slot in the service qeue, I fitted a new half of an Anderson plug, re connected & immediately the engine m'ment light disappeared & the car drove like always & quite OK. Towed & traversed the sandhills of Googs all OK and it ran beautifully - like normal. However, the battery did not charge for the whole 2,000 km trip.
What the hell is up?
Why, when I was mucking about removing the trailer Anderson plug, adjusting terminals etc after the tractor place, did it not come out of limp mode - but it did next morning?
More importantly - how do I fix the faulty engine managment issue it if it happens in remote regions?
Cheers for any thoughts. :cheers:
Rick
I am guessing you have a earth fault, is your earth on your trailer connected to the earth on the patrol`s chassis or direct to the Patrols battery?
Also as it was pointed out to me on Xmas day when I was stranded with faulty 02 sensors
BUY A BLAZT cable blaZt - Infiniti, Nissan software scan tool, data cable, reset check engine light
Here is how to check the engine fault code and clear it.
HOW TO SWITCH DIAGNOSTIC TEST MODENOTE:
+ It is better to count the time accurately with a clock.
+ It is impossible to switch the diagnostic mode when an accelerator pedal position sensor circuit
has a malfunction.
+ Always ECM returns to Diagnostic Test Mode I after ignition switch is turned “OFF”.
How to set diagnostic test mode II (Self-diagnostic results)
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the MI starts
blinking.
4. Fully release the accelerator pedal.
ECM has entered to Diagnostic Test Mode II (Self-diagnostic results).
How to set diagnostic test mode II (Heated oxygen sensor 1 monitor)
1. Set the ECM in Diagnostic Test Mode II (Self-diagnostic results). Refer to EC-52, “How to set diagnostic
test mode II (Self-diagnostic results)”.
2. Start Engine.
ECM has entered to Diagnostic Test Mode II (Heated oxygen sensor 1 monitor).
ECM will start heated oxygen sensor 1 monitoring from the bank 1 sensor.
How to switch monitored sensor from bank 1 to bank 2 or vice versa
1. Fully depress the accelerator pedal quickly and then release it immediately.
2. Make sure that monitoring sensor has changed by MI blinking as follows.
How to erase diagnostic test mode II (Self-diagnostic results)
1. Set ECM in Diagnostic Test Mode II (Self-diagnostic results). Refer to EC-52, “How to set diagnostic test
2. Fully depress the accelerator pedal and keep it for more than 10 seconds.
The emission-related diagnostic information has been erased from the backup memory in the ECM.
3. Fully release the accelerator pedal, and confirm the DTC 0000 is displayed.
PBIB0092E
PBIB0093E
ON BOARD DIAGNOSTIC (OBD)
SYSTEM TB48DE A/T (WITH EURO-OBD)
Malfunction Indicator (MI) (Cont’d)
EC-52
Fault codes as per service manual
Emission-related Diagnostic Information
EMISSION-RELATED DIAGNOSTIC INFORMATION ITEMS
Items
(CONSULT-II screen terms)
DTC*1
SRT code
Test Value/
Test Limit
(GST only)
1st trip DTC
Reference
CONSULT-II page
GST*2
ECM
CAN COMM CIRCUIT U1000 1000*3 — — — EC-121
NO DTC IS DETECTED.
FURTHER TESTING
MAY BE REQUIRED.
P0000 0000 — — — —
HO2S1 HTR (B1) P0031 0031 x x x*4 EC-124
HO2S1 HTR (B1) P0032 0032 x x x*4 EC-124
HO2S2 HTR (B1) P0037 0037 x x x*4 EC-132
HO2S2 HTR (B1) P0038 0038 x x x*4 EC-132
HO2S1 HTR (B2) P0051 0051 x x x*4 EC-124
HO2S1 HTR (B2) P0052 0052 x x x*4 EC-124
HO2S2 HTR (B2) P0057 0057 x x x*4 EC-132
HO2S2 HTR (B2) P0058 0058 x x x*4 EC-132
MAF SEN/CIRCUIT P0102 0102 — — — EC-140
MAF SEN/CIRCUIT P0103 0103 — — — EC-140
IAT SEN/CIRCUIT P0112 0112 — — x EC-147
IAT SEN/CIRCUIT P0113 0113 — — x EC-147
ECT SEN/CIRCUIT P0117 0117 — — — EC-152
ECT SEN/CIRCUIT P0118 0118 — — — EC-152
TP SEN 2/CIRC P0122 0122 — — — EC-157
TP SEN 2/CIRC P0123 0123 — — — EC-157
HO2S1 (B1) P0132 0132 x x x*4 EC-163
HO2S1 (B1) P0133 0133 x x x*4 EC-172
HO2S1 (B1) P0134 0134 x x x*4 EC-172
HO2S2 (B1) P0138 0138 x x x*4 EC-195
HO2S2 (B1) P0139 0139 x x x*4 EC-205
HO2S1 (B2) P0152 0152 x x x*4 EC-163
HO2S1 (B2) P0153 0153 x x x*4 EC-172
HO2S1 (B2) P0154 0154 x x x*4 EC-172
HO2S2 (B2) P0158 0158 x x x*4 EC-195
HO2S2 (B2) P0159 0159 x x x*4 EC-205
FUEL SYS-LEAN-B1 P0171 0171 — — x EC-218
FUEL SYS-RICH-B1 P0172 0172 — — x EC-227
FUEL SYS-LEAN-B2 P0174 0174 — — x EC-218
FUEL SYS-RICH-B2 P0175 0175 — — x EC-227
TP SEN 1/CIRC P0222 0222 — — — EC-235
TP SEN 1/CIRC P0223 0223 — — — EC-235
MULTI CYL MISFIRE P0300 0300 — — x EC-241
CYL 1 MISFIRE P0301 0301 — — x EC-241
CYL 2 MISFIRE P0302 0302 — — x EC-241
EC-38
ECM
CYL 3 MISFIRE P0303 0303 — — x EC-241
CYL 4 MISFIRE P0304 0304 — — x EC-241
CYL 5 MISFIRE P0305 0305 — — x EC-241
CYL 6 MISFIRE P0306 0306 — — x EC-241
KNOCK SEN/CIRC-B1 P0327 0327 — — x EC-247
KNOCK SEN/CIRC-B1 P0328 0328 — — x EC-247
KNOCK SEN/CIRC-B2 P0332 0332 — — x EC-247
KNOCK SEN/CIRC-B2 P0333 0333 — — x EC-247
CKP SEN/CIRCUIT P0335 0335 — — x EC-251
CMP SEN/CIRC-B1 P0340 0340 — — x EC-257
TW CATALYST SYS-B1 P0420 0420 x x x*4 EC-264
TW CATALYST SYS-B2 P0430 0430 x x x*4 EC-264
PURG VOLUME CONT/V P0444 0444 — — x EC-269
PURG VOLUME CONT/V P0445 0445 — — x EC-269
VEH SPEED SEN/CIRC P0500 0500 — — x EC-276
PW ST P SEN/CIRC P0550 0550 — — x EC-278
ECM P0605 0605 — — x EC-283
MIL/CIRC P0650 0650 — — x EC-286
TCC SOLENOID/CIRC P0740 0740 — — x AT section
L/PRESS SOL/CIRC P0745 0745 — — x AT section
ECM BACK UP/CIRC P1065 1065 — — x EC-290
INT/V TIM V/CIR-B1 P1111 1111 — — x EC-294
ETC ACTR P1121 1121 — — x EC-299
ETC FUNCTION/CIRC P1122 1122 — — — EC-301
ETC MOT PWR P1124 1124 — — — EC-309
ETC MOT PWR P1126 1126 — — — EC-309
ETC MOT P1128 1128 — — — EC-315
HO2S1 (B1) P1143 1143 x x x*4 EC-320
HO2S1 (B1) P1144 1144 x x x*4 EC-327
HO2S2 (B1) P1146 1146 x x x*4 EC-335
HO2S2 (B1) P1147 1147 x x x*4 EC-348
HO2S1 (B2) P1163 1163 x x x*4 EC-320
HO2S1 (B2) P1164 1164 x x x*4 EC-327
HO2S2 (B2) P1166 1166 x x x*4 EC-335
HO2S2 (B2) P1167 1167 x x x*4 EC-348
ENG OVER TEMP P1217 1217 — — — EC-361
CTP LEARNING P1225 1225 — — x EC-372
CTP LEARNING P1226 1226 — — x EC-374
SENSOR POWER/CIRC P1229 1229 — — — EC-376
CKP SENSOR (COG) P1336 1336 — — x EC-381
Items
DTC*1
SRT code
Test Value/
Test Limit
(GST only)
1st trip DTC
Reference
CONSULT-II page
GST*2
ECM
NATS MALFUNCTION
P1610 -
P1615
1610 - 1615
— — x EC-50
P-N POS SW/CIRCUIT P1706 1706 — — x EC-388
BRAKE SW/CIRCUIT P1805 1805 — — x EC-395
APP SEN 1/CIRC P2122 2122 — — — EC-401
APP SEN 1/CIRC P2123 2123 — — — EC-401
APP SEN 2/CIRC P2127 2127 — — — EC-408
APP SEN 2/CIRC P2128 2128 — — — EC-408
TP SENSOR P2135 2135 — — — EC-415
APP SENSOR P2138 2138 — — — EC-421
I thought... and has been my experience... that when a car goes into limp mode in order to get it cleared you have to disconnect the battery for some time for faults to be cleared. Hence why it was OK the next morning (presume you may have disconnected the battery to fit anderson plug), and why you didn't see an 'immediate' fix to your limp mode problems (simply unplugging and replugging the plug would not clear the codes).
Not sure why an anderson plug would cause limp mode problems, unless ECU picked up non charging issues.
My 2c worth.
Cheers,
Josh
more info
Thanks blokes -
I will copy that diagnostic instructions & carry it - but phew, not sure I can do all that if broken down in the bush.
Sorry, forgot to say I twice disconnected the battery - 2nd disconnect was for half an hour - in an attempt to get system restore - or some such forlorn hope!
Trailer is earthed through trailer light connections - a seperate, conventional round trailer lights plug to the charging pAnderson.
Rick
Hi Rick, it's Rick.
Get the Blazt cable and software. Run it on little laptop for car or your good laptop if you want. Can read codes and reset them. Tells you more about the car than you can imagine. ie, the two temps for the auto etc. So much info to be had. I have plans for a diy vid for it soon. Deditcated to 4.8's as it's what I've got. Watch this space......
Actually, I'm with the vid man right now. I'll annoy him about it.
Hi BowTieGQ,
I've been looking at getting one of those Blazt cable and software setups for a while. Did you get yours direct from the above link? What sort of $$ did it end up paying if I can ask?
I've got a 02 4.8 and the Blazt system looks the goods.
Im pretty sure it was BowTieGQ who gave me the best advise I have ever been given for free, " buy the Blazt cable" which I did THANK YOU! THANK YOU! THANK YOU!
Mine cost about $120 for the cable and software and arrived just a couple of days later, They even replied to my email on boxing day
That cable and software has been the best tool I have ever brought, cant thank you enough
I use a a 10" netbook, which is always with use when we travel, and the cable lives in the glovebox full time
rmoore does your anderson plug at the back of your patrol connect direct to the battery or to the chassis?
have a look around this site How to wire your camper for wiring ideas, because to me it sounds like you have a earth / wiring issue, or even a corroded breaker
I forget what it cost exactly but about $200ish for cable and software. Nothing it can't do. Well almost. It is a work in progress but updates are free so anything is possible with what you purchase today. I have a beta version that does ecm, bcm, tcm, abs, srs and others but not needed for Patrol. Runs a full virtual dash with more info than can fit on the screen but is selectable to show what gauges you want.
The gauges display in old school fashion with a needle but also show in the centre the actual reading be it voltage or other.
You can even do logs of all kinds of things and compare with a default log to see what is wrong with yours.
The more of us that use it the better we get at dealing with our issues and the better the developers can add stuff based on feedback. I have added heaps and they always listen and improve if possible.
Discussion Starter #9
OK, will suss the earth issue asap. Thanks for the diagrams, etc.
Yobbo48, I'll need to look in daylight hours, but methinks it hooks direct to the battery.
Bowtie (Rick); Appreciate your suggestion. However, I don't want to carry the laptop in the bush as it's just one more unnecessary item. I have a 7" GPS touch screen with moving map function & Ozi and 1:250,000 topo maps + hema maps etc. No other need for a laptop - when I get back to civilisation I can talk on the phone for all other matters. I sure don't miss emails - one of the reasons I go to the outback is to leave all that crap behind. Thus I am a bit reserved about getting a Blatz cable. But I am still listening to your suggestions.
Fair call mate and agree with you. Can leave it at home anyway. Just handy when travelling. I have an onboard laptop to do gps and other things so for me not an extra item to carry. Lives on special shelf below glovebox.
Discussion Starter #11
Yobbo48,
which earth is best to use - chassis or battery - and Why????
Rick
1 - 11 of 11 Posts
