Hi, I have a GU series 3 Nissan Patrol 3.0 litre diesel, Every time I tow our 17 ft Caravan with the outside temp over 30 deg it over heats. The only way to cool the GU down is to open the windows & turn on the heater.
The standard nissan radiator has been fully cleaned out with rods and has no blockages. I also had the water pump & thermostat replaced 2 years ago.
I was told I need a larger multi core radiator & not the standard type that I have.
Is this correct? :anger:
