Hi all, just noticed that when my parking lights are on, my rear led combination lamp ( in the rear bar)from opposite lock is playing up. Only 1 led out of the 24 is lit. When I press the brake, there is 6 leds on. The blinker is ok as thats a different side of the lamp and works good. I pulled apart the connector and cleaned it with contact cleaner and I put a multimeter across the wire for the the parkers. It read 12.2 volts (good) Earth is fine as well.
Do you think the lamp assembly is stuffed?
Also has anyone taken the damn lamp out of the bar? Got me stuffed how to get it out after you undo the 2 bolts holding it in the bar.
Thanks
Pen
Thanks
Pen
