1 - 8 of 8 Posts
Hi guys,
Just wondering if anyone can tell me the height between the top of the Outback Drawers fridge slide and the Rear Rack and Dividers top shelf?
I have a 60L trailblazer fridge and would like to know if the fridge will fit under the top shelf before purchasing.
Thanks in advance
Regards
Craig
Not sure what you mean by rear rack and dividers, but from the top of my Outback draws fridge slide to the door frame is 630mm, hope this helps.
This is my 60l Engel with the divider & rack and there is plenty of room to open the fridge door. The measurement from the fridgeslide to the rack is 550mm
Thanks guys, I believe based on the pic and 550mm measurement should see the trailblazer fit as it is 450mm in height.
Thanks again for the quick replies.
Make sure that the fridge can be far enough toward the centre line of the vehicle so that once it is slid out, the lid can open and still clear the door. Can be an issue with some of the big trailblazers.
Craig
1 - 8 of 8 Posts
