1 - 5 of 5 Posts
Hi guys,
Today the old girl (120k) decided to cough a few times and has thrown a P0192 code on the scan gauge.
Can someone kindly confirm the code in the patrol is the same for the generic code below
(Have checked ARKSNINS reference manual - which does not mention the code.)
A generic coding is:Fuel Rail Pressure Sensor Circuit Low
Possible Causes: Excessive resistance in the circuit - Low or no fuel - Wiring harness connector of the fuel pressure sensor - Fuel Rail Pressure Sensor - Fuel Pump
Vehicle:
- does not have any engine management lights on dash showing.
- starts
- is fitted with Chipit (mild tune) EGT / Boost /Dawes valve
Has anyone had this issue before - and can direct me where to explore a fix?
Guido
Thanks DieselTuner,
I'll was intending the disconnect the Chipit tomorrow and take it for a run.
I didn't install the blank fuel relief valve promoted by Chipit - didn't make sense to me
Is there any other test to isolate whether it is the fuel relief valve?
Guido
Started with the easy things - cleaned the MAF & swapped in a new fuel filter.
Seems at this stage to have cured the issue.
Guido
1 - 5 of 5 Posts
