1 - 2 of 2 Posts
My car was showing a code p0330 for the knock sensor bank 2 , So I went and replaced the knock sensors both . After 2 days the code showed again went and changed the harness it was fryed , couple of days again it threw the same code so I went again and changed the knock sensor again I was happy but after two days it threw the same code again !
engine coolant temperature is within range : 80-83 C
just cleaned my fuel injectors .
Going to change the fuel pump later on.
could anyone help me here?
Thanks.
Hello, did you fixed the problem? I have same error on my car
1 - 2 of 2 Posts
