The Member Formerly Known as Lusty Dusty
Giday Folks.
Been poking around the net and noticed that off the shelf extactors are still available for the G60 engine. I've got a P40 MK and no extractors are listed for this model.
I've allways assumed, apart from some minor changes, they were basicaly the same block. Has anyone bolted a set on and if so were any mods needed?
Cheers....Lionel.
1986 SD33T SWB
I always thought that the manifold bolt patterns were the same.
Bolting up to the engine is one thing, but its likely the extractors won't bolt up to the rest of your current exhaust, and you possibly may have to deal with chassis clearance, or fouling on other engine bay items.
Can't really help much more, but a couple of points to consider.
I have read that they fit with minor modifications. PM David_S, he is a MQ P40 guru!
Thanks fellas, I'll send David a PM.
Cheers....Lionel.
