1 - 13 of 13 Posts
Nissan patrol gu
Does anyone know if you can get auto paint (correct code) in a spray can and if so where
GUII ZD30DI Wgn
I had a can of paint made to match my old girl early last year at supercheap maroochydore, very professional and excellent match. Just take the code in with you.
1986 SD33T SWB
As mentioned, super cheap do it. Otherwise most auto paint suppliers will be able to do it for you as well.
We had a bunch of our adult children home over Christmas and were short on cars one day so borrowed the FIL's car since it hardly gets used. Did the right thing and filled it with fuel afterwards. Opened the fuel flap at the servo by pulling the release leaver and the flap snapped off its hinge and fell on the ground without it being touched. Damn! Bought a new filler flap off ebay which comes unpainted for $40. Went to Supercheap and found that I had to buy plastic adhesion primer at $20 and clear coat at $20 on top of the custom mixed touch up paint at $35. It cost almost twice as much to paint it as the price of the part. Still, it was cheaper than hiring a car and the FIL still thinks I'm a good bloke.
2001 GU ST TD42t coil cab (gold)
Is the Supercheap version the 2 part type where you punch the button in underneath to mix the 2 parts or just a standard can?? I really need to touch up where my battery leaked.
1 part. Just shake and paint.
OK I prefer the 2 part ones you can get at some of the paint shops, seems a bit better finish. Not totally sure what it is, not a true 2 pak but I think it is a hardener.
Nissan patrol gu
Discussion Starter #10
I’d like to know where to get these
Yep Supercheap.
I get mine from a.proper paint shop when in brisbane. Dont remember the name
1 - 13 of 13 Posts
