1 - 16 of 16 Posts
Late last year I began to have the patrol death wobbles. Found the panhard rod bushes were cactus. I ended up having problems getting the nuts off the chassis end (used a breaker bar and jack to no avail). Ended up taking the car to a local mechanic who got it off and replaced the bushes and refitted for about $100.
Last night towing the tinny at about 100km/h the lower mounting nut came off. Only just managed to stay on the road and madly swapping lanes. Lucky nobody else was next to me (dual carriageway) or it happened on the way to work as I live in the hills. I would have ended up in the trees or had a head on.
No damage to the rod and I have managed to find a bush kit local that I can press in today. Anybody had this happen to them? Before I go and have words to the mechanic for not tightening correctly.
Yes it's a pretty common thing, lucky no one was hurt, they have a habit of coming loose, I'd say if they're were replaced last year sometime the mechanic has tightened them up but it has gradually worked its way loose, use some lock tite on the threads and replace the pan hard nut with a new genuine one.
Someone else reported similar a few months ago, like you it happened after work had been done.
4x4 Addiction
Same has happened to mine, I drilled my nut and put a split pin in it.
Cheers,
I can't get a genuine nut one until Tuesday. Got one from a wreckers. I'll clean the bolt and nut up and locktite it on to get me mobile.
All done and $270 down for the tow. It was free for the car through insurance for 50km but not for the tinnie :rolleyes:
Geezus you were lucky to keep it upright. That would be bloody frightening. I've got loctite on mine and properly torqued up but even without that previously I've never had that happen.
Can't help but wonder if this is a symptom of over tightening at some stage.
Discussion Starter · #9 · (Edited)
I'm no expert but the bush sits proud of the panhard rod housing and has a lip on it. So you tighten a nut with a washer down on rubber, nolathane etc. When that bush material deteriorates the nut must not tension against anything? Is that right?
Edit: the nut must tension against the cupped washer that sits against the panhard rod bush housing.
The nut should tighten against the shaft not the bush. It will compress the bush but that's not what's holding the thread. Often when over tightening the thread is damaged.
Discussion Starter · #11 ·
Okay. So the nut has a cup in the base to meet the post (shaft). I didn't have a look. Should of.
mine parted comany with me on a track 2 hours from home plus the bush as well only found out driving to air up place wobble like hell.
had to drive a fair way at 20 Kph till found a garage and phone a mate to trailer the truck home
i think they are mechanical lock nuts?
"shouldn't be used twice" and if you do give the tabs a wack with the chisel OR use a nyloc, temperature shouldn't be an issue.
Discussion Starter · #16 ·
After that experience, and I've had a few blowouts, plus raced off road on bikes, I'll mig weld the bastard on!
1 - 16 of 16 Posts
