1 - 5 of 5 Posts
nissan safari
Hi,
I just installed a EGT guage and I'm having dramas as the Park light front and rear will not turn off even when the ignition is off. Any common reasons for this would be great. I have pulled to fuse to stop the battery going flat but dont want to have to do this all the time :)
Thanks for any ideas in advance.
Jurgs
Quickest Tyre Deflator On The Market
If your EGT gauge has a light in it, you may have wired it up wrong, take the positive off the gauge and see if that solves the problem. Where did you attach the earth for the gauge?
nissan safari
Problem solved guys. Was a combo of a damaged positive and earth wire. Everything is working sweet now
Cheers for the help!
1 - 5 of 5 Posts
