21 - 37 of 37 Posts
nissan safari
Discussion Starter #21
more parts
Water pump, viscous fan clutch, water pump gasket
Turbo cross over, (too small for my Turbos!)
Exhaust manifold heat shield
two Rear coil springs,
two front coil springs, ( one still tied in compression to allow fitment)
nissan safari
Discussion Starter #22
still more parts
clutch P/Plate and Friction Disc
Front Fender Flares, R&L
Three Fans, 0ne is 143mm Bolt-Centre-Diameter
Two Fans are 134mm, Bolt -Centre-Diameter
(one of these is quite old, would only use it as an emergency fix)
Primary Fuel Filter/Primer Pump/ Water separator and drain
comes with old filter approximately 1000km,
Reactions: GR-sharky
nissan safari
Discussion Starter #24
sorry Pitbull,
I didn't see this.
yes, I do.
Safari Hoarder
I'll be sending you the photos of what i need plus a few more bits....bought a minty Y60 from the phils
nissan safari
Discussion Starter #29
Hello team!
I must apologize for not tending this thread a bit better....
Long story short, the shorty named Crawlii, and the LWB named Trollii, have a new owner...
I still have a few smaller bits and pieces, but those riggs have a new home.
Reactions: geeyoutoo
nissan safari
Discussion Starter #31
Hey Twinotter... what parts did you need?
Very likely I can still help....
nissan safari
Discussion Starter #32
Murrdawg... you still after a diff?
nissan safari
Discussion Starter #34
Hmmmm... ACME head Hole... right or left handed.... I have both.
Hey Grippy!
I know that this is likely in vain as you've sold the trolls, but would you happen to have a set of auto or manual hubs laying around? I just took mine off and theres chunks of metal laying around, figured they're both due for a change.
Cheers!
nissan/patrol
I picked some AVM manual hubs off ebay last year. My factory hubs started as auto then converted to manual then they just wore out. My be your best option.
Thanks!
I actually ordered 2 of the AVM hubs from amazon yesterday.
I stopped by my local Nissan dealer yesterday, a new auto hub was 630 retail and 425 my cost.
I figure I can buy 6 AVM hubs for the same price, so it's not a bad even if they dont last as long.
21 - 37 of 37 Posts
