1 - 2 of 2 Posts
Hi All,
Somehow my teenager managed to break one of the 2 plastic fittings the rear passenger door
armrest screws into in the door through the trim.
I hope the above makes sense .
I can still screw it in but it hangs loose like the fitting is chewed out as the screw will not tighten.
Before I start pulling door trim off does anyone know if there is a replacement part or a way to fix this?
I pulled all mine off the other day after I found and fixed a rattle in the catch on the passenger side, mate the best option may be a wrecker, it could be as simple as the plastic plug they screw into but you won't know until you get it off, not that hard to do, so I'd be doing that first.
1 - 2 of 2 Posts
