1 - 9 of 9 Posts
Patrol 2.8 TD
Bloody window wont go down, when i trip the motor it goes down no problem so motors fine. Went to nissan yesterday and purchased a new power window switch for that side.. $85!
Installed it and you guessed it.. didnt fix it
Any idea or is it off to the auto electrician? :headwall:
Patrol 2.8 TD
no because im able to lower the rear windows fine from the drivers side. with your diagram in mind i should add i am unable to lower the front passenger window from the drivers side either.
Patrol 2.8 TD
So do i just buy the whole switch panel with all 4 window switches?
or am i chasing just the single switch on the drivers side for that window?
GU8 CRD
If you are handy with a soldering iron, the switch from the "old" passenger side will most probably be the same as the crook one on the drivers side. Will just need a bit of rewire and solder to replace.
1 - 9 of 9 Posts
