1 - 7 of 7 Posts
My front calliper is a bit tired. Is there any good quality overhaul kit available ? or those ebay complete unit any good? Are there any part number that I can buy for the calliper seals from Nissan?
532294
1998 2.8GU wagon
I used the kit from online auto parts & no problems after a couple of years.
Reactions: patrol97
I have hydraulic brake installed, don't need tb48 pad, just the zd30 pad and it totally changed the brake to next level way better than tb48 brake. But I think the front brake calipers need overhaul soon given the fact that hydraulic system produce much higher pressure. Thanks for the suggestion, I will give the online parts a try
Is it the right part number for the 2006 Gu4 front brake rebuild kit? 41120-VB225. It says repair kit for both Tokico front calipers. Called Nissan, but never be able to talk to the parts department.....
I got the seals kit straight from Garry at NIZZBITS, just to be sure I was getting the correct thing.
Good advice, Garry has never let me down in all the years I've been buying my genuine spares from him.
1 - 7 of 7 Posts
