1 - 10 of 10 Posts
Hi Everyone, this came out the exhaust of my Y62 patrol
I was positioning it in my garage; started and stopped the engine a couple of times
Then I noticed this, how concerned should I be
What is the reason for this?
Automotive tire Automotive lighting Wood Asphalt Road surface
It was parked on the drive over nightshift, so I started it up and reversed it into garage. Hadn’t been running long then I stopped it thinking I was in The garage enough, but wasn’t so started it up again to move back some more.
wasn’t running long so engine wouldn’t have warmed up to much
1989 GQ TD42 wagon
Hydrocarbon fuels burn to C02 + H20. If the engine and exhaust is cold, the H20 component of combustion can condense and drip out the end of the exhaust pipe.
So it must always be better to run the patrol up and allow enough time to heat up
Alternatively should I be allowing the patrol time to idle prior to turning off when hot, or is it just one of those things you accepted
Just wondering if it can be minimized, so I don't keep getting this mess all over the garage
The watery black junk can't really be avoided completely - although frequent shorter trips will lead to it building up.
EGTs on idle aren't enough to clear out the exhaust (in fact it'll probably get worse) - almost like the DPF regen runs for newer diesel vehicles, you need that higher RPM higher load/temp situation to really dry things out in there (e.g. a 10-15min freeway run).
Winter will be worse, as it will be if where you live gets cool and humid for any significant length of time.
1 - 10 of 10 Posts
