Johan;Hi José
Try this site for part number lookups.
400 - FRONT AXLE for Patrol 160 Nissan Patrol - Amayama
Thanks for this gif, really is all I need for my problem.
Now, to buy....!!!!
Again, Thanks.
Johan;Hi José
There are decalls available which you can stick on the stalk, then just a few layers of clear coat and ready. I resprayed mine black before sticking the decals on them.Those door panels look excellent mate.
The combo switch looks good too. How did you restore the white marks? Paint and a very small paint brush?
I've never bothered trying lol.
Sounds like you have a similar problem to myself, leaking from the cover plate bolt. I've put it down to the bolt or threads just not quite right.. was thinking a little bit of liquid thread sealant should stop itI've made some new stickers to put on the tailgate
And painted the wheelhubs in grey.
I struggles with an oilleak on the injectionpump. Oil was dripping from the cover plate, which is a bit strange to me since I believe there is no pressure in the chamber behind the cover plate and it was leaking a fair amount.
I'm also dealing with a faulty oilsender. Whit the ignition on and engine not running, it reads 6 bar. First I thought it had something to do with the 2 wires. Switching them didn't helped, the engine was turned off by the DPC-module. Could it be a mass problem, since it's always reading max pressure?
Interesting, never heard of the rear wheel handbrake on a 260.@james008
Nope I've ordered a kit and the springs didn't fit. Apparently, the kits are for the 260 2.8l (Spanish model). They have the handbrake on the rear wheel, hence this different setup.
I've managed to get a spring from a wrecker. I think I've also made a mistake by not adjusting the adjuster, I thought the brakes were self-adjusting (by the steel wire), but apparently not. The brake shoes are now just running against the drums. I've put the car on jacks, let it run in 2nd gear and the engine stalled when pressing the brake. So I hope this is enough brake force. I took a little test on a dirt road but the rear wheels in comparison with the front wheel don't block. So it remains hard to say if they operate well enough.
