Once again the weather gods were flipping me the bird, lots and lots of rain.
Spent Saturday driving around getting all the fluids I need to refill this thing, kind of amazing how many fluids are in a td42. Ended up getting castrol products for the diffs / transfer and transmission. Nulon premix for the coolant and delo 400 for the engine oil. I have had good experiences with all of those products so hopefully I made the right choices.
Sunday I made a bit more progress on the intercooler. The passenger side is on hold until I source a 180 silicone bend, so while I wait I hacked off the other cast end tank and started work on that side. I cut out the top and bottom plates for the drivers side end tank but forgot to take a photo, I did grab this photo showing the position of the silicon in relation to the end of the core.
I also did some work on the other side of the engine bay, refitting the coolant overflow tank and redesigning the mount for the vacuum reservoirs.
Due to the radius fab air box the coolant overflow had to move anyway, I basically just moved it along the wall a bit and used some nutserts with spacers to secure it.
I also had to redesign the vacuum reservoirs because of the top mount intercooler and high mount turbo. To be honest I wanted to move the vacuum reservoirs anyway, there design was dumb and took up heaps of room when they could have been tucked out of the way quite easily. I managed to get them in line on a single piece of aluminium right up against the wall next to the coolant overflow. There is a bit of loom in that area for the power antenna so I spaced the aluminium bracket out 20mm and left the loom as is.
I also started work on my raised shock towers and managed to finish one off. Instead of spacers I picked up a second set of towers from the wreckers. I've cut the second set so I get 50mm extra height when I weld them to my originals. Apart from my slightly ****ty welding it's all going to plan.
I test fit the first one and it works great, plenty of room at the top and it only touched slightly on one side which was fixed with some gentle massaging from a great big hammer.
If your going to extend the towers you need to run a hole saw through the top of the body over the tower, there is no way to access that too nut on the shock absorber without a hole cut in the top.
