1 - 20 of 20 Posts
Hay guys
I was just wondering what gauges you guys are running (mechanical, Electric) and if a mechanical boost gauge fits in the replacement pillar pod.
Thanks Jason:grin:
Autometer boost & pyro
The boost is mechanical and the pyro is electric.
Autometer - Mech Boost, Elec Pyro. The only thing I did was get a 90deg elbow to go on the back of the boost gauge as theres not enough room with the straight fitting.
I have a dual electric McNally Pyro/Boost in one and looking to install a transmission temp guage in the other
NISSAN
VDO Boost Mechanical & VDO Pyro electronic and yes it is a tight fit for the boost line tube, but go it in without kincks
I've got a Exhaust temp, volt gauge and mech oil pressure. All auto meter, imported from the U.S.
I didn't want a pod, as night driving would have been annoying, and they look tacky.
I bought cups with the gauges and installed them below the radio, just above the 12 volt outlet, looks much neater.
hey,
i've got a autron pillar pod and autometer cobalt gauges.
mecnicla boost gauge and electric pyro gauge.
im fitting them at the moment there has been a few problem's with connections and get it to fit.
i did the same a 78oll with the 90 degree bend on the boost gauge
nissan gu iii
there is a gauge i seen and it have like 5 different things in it. It is only for like the 08 patrols. i think it was like little sq shape.. anyone know what i am talking about?
if you do, do you have one and like it?
Go Hard or Go Home
Ray has it as well as many others. A great tool to have for the CRD motor.
Get one...... you won't look back.
Check out the scangauge website to see all the readings from the gauge.
http://www.scangauge.com.au/
Go Hard or Go Home
nissan gu iii
No.
ECUTalk will be suffice.
ECUTalk - News
And the related thread.
http://www.patrol4x4.com/forum/niss...-consult-software-now-supports-diesels-49013/
Not quiet as good as the Scan gauge, see their website for the variations between the two.
Have a read & you will see what I mean. I thought you needed the support for a 2008 model CRD hence my prior suggestion for the Scan gauge. But since you want one for a 2006, get the ECUTalk
thanks paul.. i will look into the ecutalk :)
Go Hard or Go Home
Do any of the OBD tools work at all with the trusty ol' 4.2 donk?
Cant comment on your rig, speak to petefire427, I believe he has one fitted to his 2006 4.2 or contact/Pm Peter from ECUTalk to confirm.
Ring In..... for now
Thanks Paul & NewKleer
yeah, its a '99 TD42T so I'm pretty sure there's nothing in there for it to talk to :(
its for OBDII, and if normal OBDII stuff like scanguage doesnt work, its very unlikely it will. for those the scangauge works for (CRD ZD30) then it may work
1 - 20 of 20 Posts
