Hi,
Last night I filled up my GU 4.5L Petrol with Pertol from the Shell at Wahroonga in the Pacific Hwy just off the F3.
I still had about 80km left in the tank but thought I'd fill up there because it was $1.31 and aerlier I'd seen it over $1.50.
Anyway, I managed to drive all of 9.2km from the petrol station before the car began loosing power, chugging and unable to go anywhere. I pulled over and the car struggled to idle at 200 RPM.
The car would no longer start and has since been towed. The NRMA couldn't get it started, however, when he took off the fuel line at the engine and squirted in his own fuel it did tick over much healthier but obviously couldn't have it running off a little squirter bottle.
Does this sound like water in the fuel? Or the fuel pump or something else?
What can I do with it? Is there a fuel drain point I can check for water? I'm thinking of going to where it was towed and change the fuel filter, drain the lines, see if I can drain the tank a bit and see how I go.
Can you suggest anything else or describe where the fuel tank drain(s) is (if it has one)?
Thank you
Thank you
