hey guys,
I was heading to my mate place last night and got to about 1km from their place and started going up a little hill and the td42 in my gq lost power. so put the clutch in and braked and it was idling fine, all temps were fine, building boost fine etc but whe I had it in first and released the clutch it would rev to 1200rpm then cut out on its own unless I am quick enough to put the clutch back in and then it goes back to idle.
I have a little lift pump on it and noticed it would run with the pump on or off for a bit (when it first happened while trying to suss out the fault) but then I tried it with the pump off and wouldn't fire up, switch it on she starts and idles.
im thinking the injector pump is gone but doing it at 11pm last night in the rain was abit hard to find the actual fault so will have a look over the weekend but has anyone got any ideas?
93 gq td42 silvertop kinugawa td05 turbo etc stock pump as far as I know and if the odo kms are correct the cars done 525000kms.
cheers jc
cheers jc
