That is what I sort of gathered from the photo!@Jordan
From what i see in the pictures from FaceBook, the device is in fact a airflow meter housing redesigned. It seems to pull out a bit the sensor position, so the airflow is not completely "reported" to ECU, so, more air enters into the intake. I might be wrong, but that is what i see from the picture. If anybody has additional info, post it here.
@Orso - try and lower the idle voltage to a (lets say) 1.9V. See what happens.
Since i removed the catalytic convertor, i am in process of getting to perfect boost setting, so, from time to time i get limp mode
Hi sorry to dig up a old post, but I want to try this on my patrol, could you please advise what resistor I need please, so I can pop down to Jaycar and get one and test this mod out thankyouHere are a couple of pictures,
The first shows which wire to cut on the 4 wire MAF sensor.
I then tinned the wire.
The second shows the " test rig".
I later soldered the connections and covered in shrink tube.
Then wrapped up again with electrical tape.
It is easy!
The resister size is mentioned a couple of times somewhere in the beginning of the thread, but, you will find most have moved on to the JayCar Voltage modifier kit as it has much more flexibility and gives you the chance to "tune" your vehicle specifically. The resister mod is an accross the board measure that effectively reduces fuel input across the board.Hi sorry to dig up a old post, but I want to try this on my patrol, could you please advise what resistor I need please, so I can pop down to Jaycar and get one and test this mod out thankyou
Lack of funds mate is the specific reason, just wanna try the cheap fix till I get enough coin to buy the JDVMCan I ask what is your specific reason for wanting to do this particular mod rather than the voltage modifier?
Maybe a quick read to understand what you are about to do is a worthwhile investment in time?So something like this diode? does it matter which way the silver end goes on the red wire?
Fair enough mate, always a valid point of considerationLack of funds mate is the specific reason, just wanna try the cheap fix till I get enough coin to buy the JDVM![]()
Thats my plan mateBut just to stress again the JDVM is definitely the more flexible option longterm.
Hello Rickie3So something like this diode? does it matter which way the silver end goes on the red wire?
Thanks B&B just the simple answer I was afterHello Rickie3
The diode works in one direction only, similar to a one way valve.
Install the diode with the silver stripe away from the MAF.
Fit it and forget it.
Cheers,
B&B
Settle for a hug instead? LOLA beer for me maybe ?![]()
As we keep saying, by doing this you are globally dropping the MAF values, depending on what value diode you use, if you just want to defeat limp then you go for the lowest value you can get away with but even so it is still a global drop which "will" effect fueling which then may cause performance issues with take off etc. If your willing to accept that then it's a cheap easy way over limp.After holding off I just tried this mod this morning, and took it straight back out, with the mod my bus wouldnt pull the skin off a rice pudding, flat to the boards I could have got out and ran quicker, did anyone else strike this with this mod??
I did the same with a diode in line of the red wire on my 2000 gu2 zd30. Dropped the voltage down to around 2.10v (with egr block) no limp mode at all running up to 15psi.Good News Everybody!
First I measured the MAF voltage: 2.18
Then I installed germanium diode, and checked again: 2.11
I was disappointed by this drop of only 0.07 volts. Is the germanium diode too efficient? Does the MAF some how try to compensate for the diode and increase voltage out?
Since I had already cut the wire, I decided to go ahead, rather that turn back.
I found an old circuit board and got a silicone diode off of it.
EUREKA!
The normal diode dropped the voltage down to 1.84 or 0.34 volts less which is perfect.
The MAF voltage range is now from 1.84 to 3.96.
This is with a full boost of 15 psi.
I did my best to force a limp mode, but it would not happen. I do not notice any change in the performance.
EDIT: I did notice an improvement in performance, the wagon goes allot better without limp-mode!!
Happy Days!
Cheers,
B&B
