I have seen many of you posts, and videos on the net. Very very helpful. Thank you to you and all the members of this site. We have a similar community in France called
www.PATROL-GR.net. Some of the photos on this site come direct from the French site. Not many of us speak English, and very few australian ( ah ah ah) mate. But we all surf quite extensively.
My old lady is running beautifully, only 160 000km from 2000. First owner. I have to replace injectors. IP is fine so far, but others have experienced problems. Many of us now put 1L of 2st oil every 6 months, to keep it a bit lubricated as fuel is quite "dry" these days.
I do put injectors cleaner every 2 or 3 tanks also. and I run 100km with between 8.6 to 10.5 litres. Not bad.
Power I get out of it is fine for what I do. I have it now tuned with a 10$ chinese "wastegate actuator" connected to the IC, and diodes on MAF line at the input of ECU to compensate for EGR and 3". I will try soon another 10$ actuator, to get more boost as it will open the VNT more slowly (different spring). That's the easy bit. As more air will require more fuel... If need be I will put a voltage modifier connected to the RPM to control and suppress the limp modes as you did if they re-appear then, as If I don't let the MAF go higher at 2500/3000 with higher boost, I won't get enough fuel injected.
As I now see, we all have gone through the same analysis, ECUtalk, Nissan data scan 1 acquisitions and tuning / trials.
Funny to see so many clever (and sharing) guys all around the world !
Cheers mate.
PS : Did you find any way to overcome the altitude problem ?
Above 2000m ( I drove up to 2800m), the air density ( barometer is down to 700mbar) and lack of oxygen make the lady lazy.
