1 - 16 of 16 Posts
I have just installed a new eclipse avn726ea unit in my 2010 patrol. its really S%^ts that the factory switch only allows the aerial to go down half way when im playing cds or ipod when im not using the radio i want to be retract the aerial all the way. i have already broken 3 aerials since buying it and thats only been 4 months
i know i can put a toggle switch but i want to be able to use the factory switxh and not have 2 switchs.
has any one done this can any one help me i have tried a few things but no luck
all wired right called eclipse and they told me that new firm ware wont allow it to come down when its off radio. to resolve it i would need to update the firm ware dose this sound right to any one if so were can i get the new firm ware and how is it installed the idiot at eclipse didnt know i have looked on there site and nothing i hope some can help
looks like it or cut the wire that brings it half way or maybe one better get rid of the eclipse and get something else because my girlfriend has the ****s that her iphone 4 wont work with it. eclipse make good stuff but dont keep there software up to date.
can you recomend a good dvd deck that does everything as it should
if u cut the wire that take it to half way then ur antenna will stay up full time. as for dvd it depends on how much money you want to spend, i work for an alpine specialist dealer so my recomendation would be alpine obviously lol, and alpine dvd, nav, bluetooth, rev cam, ipod, iphone, system would be around the 2k mark. i myself am selling the girlfriends iva-w502 and kce-400bt bluetooth and dvd kit out of our corolla for $1300, its 4 months old. we are upgrading to the new iva w520, btooth, nav, etc.
Discussion Starter · #11 ·
i was looking at the INA-W900E but have been told that the stupid i phone 4 does not work with it is this true.
if not true how much are those units and does it come with the reverse cam and can you put topo maps on them
to my knowledge the ina shud work with the ihone 4.. what is it that doesnt work? iv been on holidays since the product come out 2 weeks ago so i havent had a chance to play with one yet. im unsure if u can put topo maps on the 520, im sure they take hema or they are working on an update to take hema or something.
looks like u will be doing my power antenna switch mod then,
The aerial (and the wiring) on my GQ was missing when I bought it, and I've managed to find an aftermarket electric aerial to install. The aftermarket unit (Aerpro) has a power, and earth and a green trigger wire. I have the aerial control switch on the dashboard.
Is it possible to mod the Aerpro unit to allow me to be able to control the height, either with the factory switch or with an aftermarket one?
very good question. now. depending on what aerpro antenna u got will depend on wether it will run with the height control. im not 100% sure on the aerpro gq/gu antennas but i know for a fact that you can buy a semi auto antenna for falcons etc which have full height control (basically u set it where u want it) if the antenna only has red black and green id be guessing that the height control wont work unfortunately. if it was to work it would run a minimum of 4 wires. HOWEVER!! i recons i could make a switch up that would let u run half or full height ;) :cool:
It's an AP10. It's made for a VB-VL Commodore with a few different head kits to suit other applications. It is a fully automatic model, though.
My main concern is being able to lower the aerial when I need it to avoid damage. I'm assuming that this switch you could make would be a little beyond my abilities, but I was wondering if there'd be a solution that I could figure out.
I'm assuming that activating the trigger wire is what raises the aerial, while cutting power to it would lower it. Could I wire in a simple on-off toggle switch to the trigger wire, so that I could at least cut power to the trigger and lower the aerial when I need to without turning off the head unit?
(I should add that I haven't installed the head unit yet. I'm assuming that the aerial will stay up when the stereo is on, even if I'm playing a CD or using an MP3 player. Obviously, if the aerial retracts when the stereo is playing a CD, then it wouldn't be necessary.)
yeah u can alsways just but an on off switch on the green wire and that will allow u to hav it up or down wenever needed. the setup i was talking about was height controlling.
1 - 16 of 16 Posts
