81 - 84 of 84 Posts
GUII ZD30DI Wgn
@Vamphersi Be best to get yourself a scan tool _ read and to clear engine fault codes, especially that you are considering manual boost control. Not sure of a good cheap option available for DI. Some others may advise.
If he is going to hang onto this vehicle he is better off spending a few dollars getting an ECUTalk, a simply amazing no worries tool for any DI.
@Phdv61 also, i have looking in the manual where you said and there is no mention of it for 2001 zd30. the EC section is all just wiring diagrams
I don't know what you are looking at. All is in the archive.
EC section for 2001 Patrol is attached.
Discussion Starter #83
Thanks, will look into it, it's a shame they run of consult 2, I have a good obd2 scanner
So you have OBD11 port?
What is the scan tool (read and clear codes) you are using now?
What mods to your engine and need to identify where to take boost reference from for boost controller. Where/how are you taking boost ref for boost gauge?
81 - 84 of 84 Posts
