61 - 80 of 90 Posts
Discussion Starter #61
You definitely don't want grease on any of the terminals as that will cause issues.
.The connector that plugs into the busbar is notorious for failing. It either falls off. Gets crud in it which gives it a bad connection or the wire breaks internally. Have seen several with internal breakages. Definitely check for power at the plug end then along the cable.
Glow plugs need to be disconected from busbar in order to test them although that won't effect power going to them. (Always good to test them when you get the chance anyway)
Does the relay that's attached to the Powertrain timer click when the timer starts?
Better advise than I was about to post. Forget the glow plugs until you have found the fault.
Nissan patrol GU
Yes relay to Powertrain clicks, have put grease on thread that screws into head not terminal end , did wipe cable terminal that attached to busbar.
Nissan patrol GU
Agree, ruled out glow plugs, l recall the first start with power train the led light started to get dimmer and dimmer once it went to after glow according to my brother, so thinking skegbudley might be on the money with connector.
2003 ZD30 Patrol
G’day @skegbudley i want to make the timer go to 20 seconds as it’s getting bloody cold here now (-2 this morning) but I’ve thrown out all the packaging. Do you still have anything on how to do it? I don’t want to just go pushing buttons just in case I stuff something up.
Nissan patrol GU
RAGGQ, photo of instructions on how to adjust timer settings
Reactions: RAGGQ
Discussion Starter #68
ZD30 Steven beat me to it so Ill move onto the 2nd part I was going to mention.
If your engine was starting happily enough on it's previous time setting when the weather was warmer. I would set the afterglow instead. It pulses the voltage going to the glowplugs so it will help the engine warm up without going to their maximum temp like they do when they are powered full time. It's designed for cold weather starting and makes quite a difference. Much better than cooking the head for a extended period. Try having the primary glowplug timer just for starting the car then have the afterglow run for around 20-30 seconds and see how that works.
2003 ZD30 Patrol
Great idea @skegbudley I’ll do that instead of the normal glow.
What would you recommend as an afterglow time. I still might set the normal glow to 15 seconds though. I’m getting some very cold mornings lately
Nissan Patrol
Hi Guys,
As it was time to replace the glow plugs Bosch gph900 which were installed when engine was rebuild.The first glow plug had the top section come apart which explains why she was hard to start in the Melbourne winter mornings.
I did the Powertrain timer with the led connected to the buzz bar in November last year and has been working as it should.
These glow plugs reach just short 10400klms.
This time round have gone with genuine Nissan ceramics.
Reactions: Zd30 Steven
Nissan patrol GU
Just confirming I have finally solved my issue . Everything works sweet now.. The issue was the Narva relay 4pin , seems it was faulty, replaced with new one and power to the buzzbar. I replaced the following items during problem solving. Glow plug relay, ECM relay, LED and glow plugs.
2004 ZD30di ST-L
Can 3mm 10 amp cable ok from busbar to l.e.d .(ok to use checking glow plug duration )just want to see duration of glow plugs in different start up temperatures in morning
thats perfectly fine. can even use 0.5mm wire as the current is very small.
524314
Can the LED indicator be tapped in here? I'm guessing off the bus bar would be another cable through firewall...
You can see the front of the busbar just under the intercooler. The rest of it is under the cooler. I think most people just put the wire onto the nut on one of the glow plugs. I have attached an image off google of it and will circle the wire that goes to the busbar for you.
My LED indicator is mounted under the steering wheel and connected to the buzbar at the back under the IC, then run through the firewall, keeping the run short and mainly out of the way. I don't run this type of timer, mine is a much older version of another brand, even though it has its own indicator I like to have this separate LED as a back up that stands out.
Nissan patrol GU
Back of buzzbar is where I have mine also. Easy to get at and no need to remove anything to install apart from nut on the back of buzzbar
Reactions: RAGGQ and Hords
2004 ZD30di ST-L
Went to start this this arvo. Read at the start of this thread to be mindful of the key reader. Doing a search I learnt some people had a bit of misfortune with the key reader but no pics. So am I correct to assume this is it?
524651
Anyway, I assume this is the connector at the back of the barrel going by wiring colours
524652
and then someone tapped in before me :(
524653
2004 ZD30di ST-L
@geeyoutoo I don't know how you have the dexterity to attach at the rear... I'll shorten mine when the TB comes out I guess.
524707
At least the indicator is working and it cut out after the full factory 5 minutes.
524708
Now to finish it off.
Powertrain timer is $64.99 now at Repco. Covid inflation...
61 - 80 of 90 Posts
