I fitted up the Provent 200 and thought would post my thoughts and issues.
I picked up the kit from Western filters but you could definitely save some cash if you sourced the hoses and clamps from elsewhere.
All up Costs
Provent Kit Plus drain Hose $324
8mm X 25mm Hex head nuts and bolts $10
Black Spray paint $7.99
Bracket $5
If you source the hoses yourself you will need(hoses fuel/oil rated)
20cm of 25mm hose
4 clamps to suit
1m of 12.5mm hose(grab 2m just in case of my measuring error!)
4 clamps to suit
2 X 25mm to 12.5mm copper reducers (plumbing section)
Drain hose
1m clear 12.5mm hose(2 more clamps)
Drain tap to suit(plug it with a bolt and clamp would do!)
The provent outlet/inlet is 25mm and the nissan fittings are 12.5mm
I actually used most of the hose because of a slight length judgement error!
The install was pretty basic.
Remove engine/intercooler cover.
You will see the small length of 12.5mm black hose running from the top of the engine to the air intake pipe. This is what you are replacing and plumming the Provent into.
I installed it behind that mounting point in front of the ABS so I have room for the dual batteries when that comes!
I used the bracket to mount to the body.
Don't ask what size, I took the provent mount into bunnings with me and found a perfect match.
I had to do this so the drain hose would not foul on the body.
First cut the bracket down(it was an angle bracket)
Using the first and last hole on the bracket, I positioned so I had to drill one new hole in the bracket and car mount for the second provent bracket hole closest to guard.
I did have to drill out the other holes slightly.
Fit your 25mm hoses and reducers to the provent and mount, Put clamps on after mounting or they catch and the other hoses and lines in the area.
Work out your length of 12.5mm hose from top of engine to Provent inlet (top one)I had to give mine a twist to cause it to snake into the right place/angle.
Test engine cover fit as the edge of it is like a razor and will rub and cut, mines just clear by a pube hair so to speak.
The bottom hose/provent outlet is a little bit tricky in this position but to get in the position I got it I pointed the intake inlet down a little. I did this it this way to get a little distance to the turbo
A better option would be to use copper pipe to extend the reducer and bend to where you want it rather then bending the hose which is ok but i will keep an eye on it. I think you can get a 25mm to 12.5mm reducer elbow which would be another option.
Any way the pics should tell you the rest.
All told took me about 2hrs including making the bracket
I will source an elbow and sort out the bottom hose
Oh yeah , drain hose snakes down to the chassis rail where I cable tied it , did have to shorten a little.
All up Costs
Bracket $5
20cm of 25mm hose
4 clamps to suit
4 clamps to suit
Drain hose
