1 - 13 of 13 Posts
OK. I have a Munro Racing Highflow HT18 snail and believe my tuner has failed to develop all the available power by not adjusting compensator or reprofiling fuel pin. Who has experience with this combo (11mm. pump) and what settings did you use? Thanks in advance.
That's the problem down here pat,from what I can see there's no one down here that really specializes in tuning diesels,not Like over on the big island!
Afr graph will tell you nothing about whether you a gained the best possible outcome by itself.
It is just one part that can be looked at in conjunction with other things.
But if your tune involved only fuel screw adjustment then most likely it was a waste of time money and effort.
Discussion Starter #8
That's what I'm afraid of Bambill. I asked them to tune off the compensator, but not convinced they did.
Is the tin cover still on the fuel screw?
Or was it there before even.
A pump in good condition will get around 130kw give or take a bit before fuel needs adding on the screw. And if it's a Ti the playing with the fuel screw just brings a whole heap of other issues into play.
Marty
Marty
Issues or variables?
Discussion Starter #12
Truck is a 12/06 coilcab . So mechanical pump and it has been rebuilt. New injectors also.
That depends on youre level of knowledge and from all accounts the level is fairly low for most "tuners"
Good thing I am a plumber then.
Pat, 12/06 will or it should be a tcv pump. Which i should have said instead of Ti maybe.
If cover missing or damaged on the fuel screw then ask some questions about how they did it.
Marty
1 - 13 of 13 Posts
