1 - 20 of 63 Posts
Bit of a quiz (cause i am bored) to see who can guess the reason why or who knows
Your vehicle has a dead flat battery & you take it out of the vehicle & charge it on a battery charger
When you refit it to the vehicle the fusible link blows
Why
Regards Don
voltage spike when you reconnected the batteries would be my guess. or you have managed to short out the battery with the spanner when doing it up.
do you put the positive or negative terminal on first???
Nope
Connected the positive first & nothing shorted
I will give you a hint
The fusible link blew as soon as the second lead was attached
Regards Don
Another hint
You replace the link,refit the terminals & the same thing happens
Regards Don
well now thats a different story. id say you have a short somewhere.
is it the fusable like that comes from the alt by any chance?
as assuming yours is a 4.2 there is bugger all fusable links in them. one for glow plugs, alt, starter relay, and i guess main power. i think that has them all covered.
possible short in the altenater???
Discussion Starter · #12 ·
I haven't got this problem but it can happen with any vehicle
We were talking at work today after one of the other blokes had replaced a fusible link on a hilux (not for this problem) & i asked the service manager if he had come across this problem before & he said he had but not very often
I first saw it happen about 15 years ago
Bored tonight so i thought i would put it on the forum & when someone gets the answer it will be something worth remembering in the future if this happens to someone
Regards Don
Discussion Starter · #18 ·
Fusible link is correct one for the vehicle and lets say battery voltage is 12.6 volts
Regards Don
If it has to do with charging the battery on the bench, then it is possible to have charged the battery in reverse if it was flat enough to begin with.
Discussion Starter · #20 ·
We have a winner :D
You say to the apprentice charge this battery,he connects the charger leads up to the wrong terminals & the battery charges in reverse
You fit it to the vehicle but when the terminals are connected the link blows because it has been connected with reverse polarity
Bugger to work out why the link keeps blowing until you realise what has happened
Regards Don
1 - 20 of 63 Posts
