Has anyone out there got any photos they can put up on the installation of the Racor 445R fuel filter on the CRD patrol. I'm going to install one as an additional filter to factory filter (as advised by Western filters). Any advise and photos would be much appreciated.
Shane
Hi Shane, I am going to go out on a limb here, I do not think that you should be putting an additional filter on your system without a supplementary lift pump or you could risk starving your injection pump which uses fuel to cool itself so it needs high volume of fuel to go through it.
I also note that the 445r is rated at 45GPH which may be too low a rating for the Bosh CP-3 injection pump fitted to the CRD. I have twin Facet fuel pumps rated at 30GPH each on my Di and the injection pump still goes into "draw mode" under heavy throttle.
Also note that the injection pump on the Di provides up to 10Hg of vacuum, the injection pump on the CRD (CP3) provides up to 20Hg of vacuum so it probably wants / gets more fuel flow than the Di pump.
If you are worried about water in the fuel, check out
this thread for some other ideas on how to tackle it..
Cheers,
Whitie
