nissangu
Hi all, my 2001 gu has the common rust in the radiator support panel. While it is sitting in the backyard unregistered i am toying with the idea of changing out the support panel. A new one landed at my door is $270 through partsouq.
Has anyone done this before? It looks like a fairly straight forward job- drill out the spot welds and replace then tack it back in.
Is it that bad of a job or am i missing something?
Thanks
Master Coalroller
Check the condition of the bidy mount outriggers before you start. I have one booked atm needs a new outrigger welded onto the chassis before the rad panel goes on. They rust through underneath the body mount
I tested my own solution.
Benefits :
• you do not have to disassemble the entire front of the car;
• it is a cheap and durable solution - I think - now I am watching how it behaves over time - it has two months;
• I used a rectangular 50x50x2mm, screws, whoever wants can use welding or epoxy adhesives, paint and a type of polyurethane silicone.
There are some issues that need attention.
I'm attaching pictures of what it was like and what it looks like now. I will soon present the whole work with explanations. If anyone sees errors or possible problems over time, please expose them. Thank you!
SuportRadiator - Google Drive
Does anyone have an opinion whether nicu210s fix would be legal in Australia
Benefits :
