I never had a issue on corrugations. i fitted one to my now departed Dads 1988 GQ ute sometime in the 90's due to the rag joint had broken. That rig did twice around the clock and then some because it had the odometer broken for some time which is usual for a GQ. 2 or 3 times a year he would do his usual Weipa fishing trip. In those days the cape had real corrugations 800 klms of them. The steering column is still fine. A family friend has the ute now and i do see him often, and i still do its services. I haven't noticed any column play or wear. I will check it next time in detail.
The other thing i noticed that could be a bonus is bouncing about rocks, the steering doesn't seem to have that annoying spring back or that flexing and no turn you get at times. The Mods has been around for years and by now there would be quite a few that have done this mod. I haven't seen or heard any ill effects.
The rag joint does deteriorate or gets a bit loose as time passes so for most or you, you just got use to the extra flex. If you fitted a new rag joint it would feel very much the same as this solid uni joint if not the same that is why the steering has that very much positive feel now like a new rig...
