For my GQ LWB with 60mm lift Extra-HD TJM springs, 30mm coil-spacers, ARB castor correction bushings and extended swaybar links. I now effectively have a 3.5" lift and my OME Nitrocharger shocks have gotten a bit short.
I would like to run RS5000s and I would like to retain pin-to-pin shocks up front and not use pin-to-eye adapters.
I'm from the Philippines and it's easier if I just order the correct Rancho shocks by directly giving the part numbers that I need for front and rear shocks instead of them needing to interpret what will work best with my mixed-brand set-up.
Thanks.
Thanks.
