1 - 9 of 9 Posts
Hi all,
Just about to do the rb30t conversion and had a question about the wiring. From what I understand there is 3 constant power source and 1 ignition, on the engine loom where it breaks off into the plug with 2 orange wires, 1 white and one other would I be right to wire them straight to the battery? Or would I need a fuseable link or what should I do there.
Thanks
u just need one battery to ecu
one battery to power injectors
efi relay power which powers ecu and dizzy and air flow meter
then fuel pump relay
nest of google a wiring diagram and print it out and then use a multimeter to go over the loom
that's an ecu pinout but u really should have a wiring diagram aswell
there is prob people out there wiring these a quick and nasty way without relays
just run all power wires to ign switch
run fuel pump power to ign switch
then just connect start wire and yr good to go
fitting relays takes a lot longer to get it all working properly
Running all power wires through ignition would cause computer to reset every time you turn the car off tho?
I understand what you're saying mate but have traced all wires to their plugs and tagged everything and that's what I came up with
I posted a couple of good diagrams here on patrol4x4 a few years back. They are what I used wiring mine up. I figured the neater and closer to factory I wired it, the easier to troubleshoot down the track. I'll see if I can find the thread.
Thanks Mal ill sus it over when I pull out the loom again tomorrow and double check it.
The loom I got hasn't been messed around with so hopefully is more so plug in and away we go. The main issue I was having was power to the ecu and how I should go about it
1 - 9 of 9 Posts
