Was just wondering if anyone knows and had photos of how to install the donator speed box on a gu RD28t. There’s other forms but all pictures have been removed and there hard to follow
Just tap the control wires into the wires that go to the plug on the harness side not the injector pump side. Just don't use these crappy cheap cable lock connectors. Gently strip a section of the wire and solder the control wires on. Then tape them with good quality electrical tape.It’s the one with bare wire. Positive and negative wires plus two control ones. I kind of have an idea of what to do just better to understand with pictures. This might sound stupid but do I have to tap the control wire in the plug or just into the correct wires on either side of the plug
Read steps 2 and 3 in my previous post.Can anyone tell me exactly which wires I tap into View attachment 544514
B. If you have bare 4 wires: Red and black are the +ve and -ve, the other 2 wires are the control wires.
1. Connect +ve to a power source that comes on when the engine is turned on. -ve is obvious - connect to any earth point.
2. When you unplug the 8 pin grey plug, have a look inside and you will see it has 4 pins down one side and 2 or 3 pins down the other side.
3. You need to isolate the wires that connect to the middle 2 pins on the side where there is 4 pins in the plug. connect each of these wires to on e each of the 2 wires from the power chip.
4. Orientation of the 2 wires from the power chip is not important as it will work either way they are connected.
