Ok so I had a Keas Stage II valve body and Keas Torque converter installed by a local shop in Perth, gearbox is fairly fresh from a recent build and drove fine on the way to the shop. After valve body and TC was installed During the workshop test drive the auto would’ve shift out of 1st.
called Keas (but today is a public holiday no answer).
ok shop thinks the valve body supplied is for a ZD and mines a TD ( I didn’t think there was any differences in valve bodies anyway) so he changed the solenoids over, that didn’t change a thing, puzzled and blaming the new Keas valve body he then refitted the original Valve body,test drove and it shifted fine, ( he then concluded saying ok send the valve body back as it must be that. I started to drive home got 40 kms fuelled up then When I started it up the gearbox would not shift out if first ( the same as when the new valve body was in!
Sounds like something wasn’t plugged in properly? Any thoughts would be appreciated guys as I’m 400 km from home and need the car back on road
