1 - 3 of 3 Posts
2001 Auto TD42T
Hey guys, I have a rock armour rear bar and wondering if anyone knows where to get the spring pins that lock the swingaway/allow it to swing out more when pulled up?
Automotive parking light Tire Automotive tail & brake light Plant Automotive lighting
1998 Nissan Patrol Wagon RD28ETi
Do you want a generic spring loaded pin that you can attach/use on your swing away OR do you need to replace the the spring loaded pin on your Rock Armour rear bar?
If you are specifically looking for a Rock Armour replacement there is a 4X4 place at Coopers Plains in Brisbane that deals in Rock Armour bars, they may be able to help. If you want generic then you can get them at Bunnings.
Hi mate
I have one of those bars. The metal doesn’t seem very strong especially in the corners. It passes but only just. If you hold the bottom of the striker with some multi grips you can unwind the top hat and that allows you to take the assembly out then you can go and measure at your local.
1 - 3 of 3 Posts
