1 - 12 of 12 Posts
Just wanting to know which model crd , as has the power steering reservoir and bracket has it mounted next to the battery as i have a plenum facing forward for a fmic
Thanks
Jono
ZD30 has the reservoir where you are talking about. You might be able to get one from a 3L Patrol and adapt the hoses. I have just done a FMIC in my ZD30 and moved the reservoir back to the next available bolt holes on the front of the battery tray to make more room for the intercooler pipe.
515977
The ZD30 reservoir tank is already set up to bolt to the battery tray. It has a hose to the pump. You probably need to change hose fitting into the pump. I think that is shown in plumna's post above. Last photo.
515978
. This photo is from below the pump to the battery tray.
Cross country do a kit as stated above. I just used the 3.0 ressie, hoses and the fitting off the pump itself. Bracket wise I just used a piece of flat bat bolted to the battery tray.
I had wondered if the ZD fitting would work. In most pics it looks like the mounting holes are a little offset from the inlet hole on the pump and the ZD fitting looks like the offset is the opposite way to the TD. Have you got any pics.
Discussion Starter #10
There's a wrecker who has the zd res, bracket n hoses for cheap near me but i think I need the pump elbow can anyone confirm its 38mm centres external holes or for plan z is ive tapped a thread in the thinnest ally plate lol i had lying around and had a gasket for pump side
Ah, that makes sense. I just assumed you were pointing it back but that is the way I expected the ZD fitting to sit.
1 - 12 of 12 Posts
