1 - 5 of 5 Posts
something strange has happened ever since i removed the orgininal ducting and i cant figure it out. its been a few days and i've been running on gas ever since but when i switch back to petrol it just stalls. i've played with the idle screw and that didnt do anything....
it runs great on gas, no problems there. thoughts?
BORDERTREK 4X4 & FABRICATION
Anything on the intake that was joined to the carby or manifold? Does sound strange though if there wasn't. Usually with a snorkel there's a balance pipe from the gas convertor to the intake but that's for the gas :confused: However it may have been tuned on petrol to suit that as well.
Nah all the cold start vents werent connected. I'm just thinking if I screwed the idle adjuster all the way in and then backed off when it run would work? When I played with the idle I didn't go in alot in fear it would make ig worse.......
played around with the idle screw some more even upped the throttle adjustment..... im gonna look at the timing and if that doesnt work im booking it in for a gas tune and long awaited tank test. (that way they can fix up this debacle)
1 - 5 of 5 Posts
