1 - 2 of 2 Posts
Hi guys, I’m currently in the middle of removing my gas system.
I’ve removed the tank aswel as the gas hose and wires back to the engine bay. I’m onto removing the 2 heater hoses and hose that goes from the gas converter to carby. Am I able to just block these off at the T joiner?
Also are there any electrical wires that if removed will cause issues?
Yeah - just block off the hoses at the "T"'s or if you can remove the T's altogether = better.
Electrically you will need to make sure the petrol pump (TB42E) is still getting power, or that there isn't a fuel shut off valve in the petrol line that needs power to open. The gas switch controls these items, so if you remove it = no petrol supply.
on some installs, the gas tank gauge is the petrol gauge when switched, but more commonly uses a led level indicator on the switch.
Reactions: Overboard
1 - 2 of 2 Posts
