1 - 5 of 5 Posts
nissan patrol guii petrol/gas
Hey folks,
Can anyone tell me how to remove the panel holding the number plate and handle from the rear left door?
I had a go today and got as far as having the two nuts from inside the door removed along with the number plate holder. I also had prised the rear panel up around the edges but there was something still holding it down.
I want to run power/video for the reversing camera.
Joffa.
yes it does. thanks heaps.
thought that i needed 2 find another screw to undo.
cheers, joffa.
Nissan Patrol GRX 2003
looks like the rear door are the same as 98-04 models...anyone tried to fit this panel to 98-04 models?
Thanks for the diagram Time. Gave me some reassurance to yank it a little harder to get the reverse camera installed.
One more tip is that at the bottom right hand corner of the plastic mould there is a little gap in the seal. You can get in there with a little screwdriver wrapped in cloth (to protect the duco) to pry it off after unscrewing the 3 internal bolts..
1 - 5 of 5 Posts
