1 - 3 of 3 Posts
G'Day guys, about to remove the starter motor from my zd30 in the morning and am wondering if anyone has come across and problems doing this or if anyone has any ideas on how to make it fairly painless.
I only need to do it to chock the teeth iside so that I can undo the front crank pully.
nissan patrol y60
put a 3/4 drive socket and bar on nut and hit key to brake loose.
Righto, so I guess as I'm looking at the front of the crank pully, run the bar down to the ground on the drivers side and just turn the key and all should be good. What about after I have changed out the seal and putting the nut back on, without starter off, how do you get it tightened enough?, I know my questions may seem odd but I've never done this before.
Cheers.
1 - 3 of 3 Posts
